Our pool equipment is installed inside a building due to HOA variances and noise. The pool is outdoors.
I originally had gallons of muriatic acid and chlorine tablets stored indoors (apart from eachother). I started to notice rust on items I had stored in there. Did some research and saw that MA should be stored outdoors as it can cause rust. I moved the MA to a bin outside but left the tablets indoors.
It’s been about a month and I was still finding rust. It’s hard to say whether it’s residual from before or whether it was new rust but I’m pretty sure the issue is persisting. Yesterday I moved the tablets outdoors as well.
Is there anything else I should do? Do I need to run a dehumidifier in there? The pool loop is a closed system in that it’s not leaking water so I wouldn’t think that would be the culprit?
