- Jun 7, 2017
- 9,150
- Plaster
- Jandy Aquapure 1400
How?
Yep, in the house. Done and the light is now solid green after starting up again... would love to understand why that worked if you know?You should have a box with circuit breakers for your pool equipment.
Thanks! Saves me an annoying cleaning process.Sometimes they just get a glitch. Happens to mine as well just loses its mind. Seldom to be sure like 1 every 2-3 months but it happens. When in doubt, reboot it!
So, just came home from a couple of days away and the check cell light on the IC40 was flashing again. Another power cycle and it’s back on solid again.... thoughts on appropriate next steps?Sometimes they just get a glitch. Happens to mine as well just loses its mind. Seldom to be sure like 1 every 2-3 months but it happens. When in doubt, reboot it!
CorrectI have never had an issue. This is the check cell light?
Probably needs a cleaning if it keeps coming on. What's your salt level currently
Sorry for the silence on this thread. It’s been a busy summer. All has been excellent with the pool by following the TFP method. Crystal clear water, etc. my TA has come down and while my pH still tends to drift up, I’m easily able to bring it back down with a smallish amount of muriatic acid.
So, everything was going great until I just checked my system. The IC40 is flashing green on “check cell”. I am reticent to call the pool company again, so any suggestions? I have ordered the cleaning system / cap from Amazon preemptively and it has arrived. I did that as I thought perhaps it’s going to need to be cleaned. But, I also thought I’d check in with you all to see what past experience tells you. I already held the ‘more’ button to show 60% used up so it should have more life on it. I also run it at 100% for 16 hours a day but I assume that’s fine to do.
I will check those out. Can I dump the acid/water mix from the IC40 after cleaning into the pool? I suppose it would lower pH a bit (which is fine).IC60 is identical size to IC40.
Remove the cell and look if you have white scale on the plates. If plates are clear then not likely cleaning will help. There are Youtuibe videos on cleaning an Intellichlor cell.
These are stuck. Any suggestions? I tried Channel locks but they just took off some of the plastic.
I tried both directions. Do you mean clockwise or counter clockwise?You are turning the large black plastic nut to the right, correct? You might try using a belt. Strap it around and try pulling it. This works well on oil filters.
