Welcome to TFP! A much easier form of pool ownership (no matter what size pool you have)!
We are also a tiny pool owner. The methods TFP gives WORK! If you follow them closely =)
I'm going to ask quite a few questions::
Welp i did it im within range . My ph should be 7.3 here in a bit . Except maybe chlorine may be a tad low . Should i raise it up one point?
Cl 2
Br 4
Ph 7.8
Ta 150
Ch 90
You need to target FC/5, so you need to use
PoolMath to add enough Liquid Chlorine to raise it from Now/2 up to Goal/5
Cya 30 to 50
I was kinda iffy about my cya levels 30ml was all the tube would hold educated guess lol
Can you post a picture of the CYA test please? So we can be sure which type it is.
Also can you let us know which chemicals you have (and are you only adding Liquid Chlorine 10%)?
(found this from your first post::
The chemicals i have are: ph up , ph down , pool shock ( pool and spa xtra blue sodium dichloro), 1" coordinating tablets (tricholoro) ,six way test strips ( Clorox smart strips).)
... Can you return any of these (unused) items to the store: (for credit towards Liquid Chlorine)
ph up, pool shock (pool and spa xtra blue sodium dichloro), 1" coordinating tablets (tricholoro), six way test strips (Clorox smart strips)
You do not want (or need) to use the shock or tablets in the vinyl pool.
We use separate stabilizer (you can buy a SMALL 16oz bottle intended for spa use), as you don't need a huge container, we still at least half our 4lb container from last year)!
