Pool border tile installer wanted (Jersey Shore)
It is really a DIY job after the pool is installed. You need to lower the water a little bit in the pool but work in the pool with water in it.
The tiles glue onto the fiberglass. Just takes someone who can do straight lines and can cut tile. Use a tile that will be a simple install and will not show installation problems.
I have read the do it yourself guides but don't have the courage to try.
