Hi. I have a Pentair Easytouch (520593), Intellichem, Intellichlor, ScreenLogic. These were new roughly 5 years ago. Two automated valves (one to switch vacuum side cleaner on and off; one to switch between returns and scuppers). Everything worked great until last fall when I installed first a Raypack heatpump (model 8450), then a pentair propane heater (model 460737). As a result of these additions the valve controller for the cleaner was coopted in some way for the heaters... not really sure what they did. In any event the cleaner circuit is essentially disabled. To get around this the pool guy(s) simply set the cleaner to run full time (valve split between cleaner/main drain/skimmer) and goosed up the "pool" speed setting. I really liked having the cleaner run separately 1.5 hrs per day, dedicated (less wear and tear on the cleaner vs 24/7); and having the "pool" run at low RPM 24/7 when no demand for more RPMs (such as when the heater(s) were running (believe when running those there is a commensurate goosing of RPM associated with those circuits). My pool guy says my controller is limited to two valve circuits... so can't reconnect the cleaner to its dedicated valve circuit.
What might be a work around? Future addition of in ground soaking tub is possible requiring additional controlled valves. Any thoughts would be appreciated.
Kirk
Kirk
