Polaris 390 wall fitting
Hello, I have a Polaris 390 vacuum. The wall fitting recent snapped off. This fitting was the stub pipe connector in 1.5 inch pipe. The attachment head snapped off almost flush with the wall, leaving the stub end stuck in return pipe. How could I got about taking the stub end out and/or replacing the attachment?
Thank you in advance and happy memorial day
In my case they did not use threaded walk adapter in the original install. It was a non threaded stub pipe, the adapter had a compression fitting I think that was inserted into pipe. The compression part is stuck in the pipe. I tried sticking needle nose pliers inside, opening them and turning to no avail
