- May 29, 2018
- 456
- Plaster
- Pureline Crystal Pure 60,000
And you had such nice straight runs in and out of the heater that you now need to criss cross. LOL I thought it was going to easy
No SWG? I left room to add one at a later date, and a check valve. The added cost for the duct work for the heater took away my swg for now
Why do you have a 3 way Jandy valve with an open port between the pump and the filter? Going to add piping out wall and use if I ever have to drain a few inches out of the pool. My filter is setup the same way so I can drain the water out for winterizing
You really don't need 2 Jandy valves for your heater bypass. You can do it with one Jandy valve and a check valve on the heater out line. Thought about that, but was leery of the check valve malfunctioning
You have an open stub on the left side of your suction facing the stucco wall? That will tie into the skimmer(s) line
Was going to see which way to can rotate, have not even take a look at the panel yetLooks good except for what you mentioned, and I would rotate the controller on top of the pump so you can better view it.
no flowis ?? Am I missing something or is that in reference to me doing my heater backwards.Most people wouldn’t have noticed if you didn’t say anything. Lol.
Looks awesome. You have a VS pump but no flowvis. That would be a handy addition.
Love the old school copper in the original setup.
They are all sch 40 pvcHey blazer...are those elbows and some of the other fixtures sanitary (non-pressure rated) fixtures? If they are, I wouldn’t risk it with all the work and new equipment. Hopefully that is not the case.
Nice, those probably aren’t Home Depot parts then, haha. Nice little sweeps. Can I ask where you got them?They are all sch 40 pvc
I am curious about the flexible tubing you have in your picture. I have not seen that used before.Most people wouldn’t have noticed if you didn’t say anything. Lol.
It's only 7am here, will check in a while, ThanksBlazer,
Looking at the 90 degree fittings it appears they may be DWV instead of pressure fittings. You can get DWV and pressure fittings in Sch 40 but the pressure ratings are not the same. They are almost identical to pressure fittings in terms of fit but should never be used for liquids under pressure. For some reason they are on the same aisle at HD which makes it easy to confuse them. The way to check is the DWV have an enlarged part on each end to slip over the pipe. Pressure fittings are the same diameter over the entire piece.
I hope this helps.
Chris
