All joking aside, has anyone proved that samples at different depths are significantly different? I’m not talking about skimming the surface for a sample but 1ft down then 2ft down etc.
Taylor Technologies suggest "To get a representative sample, draw the water from mid-pool"All joking aside, has anyone proved that samples at different depths are significantly different? I’m not talking about skimming the surface for a sample but 1ft down then 2ft down etc.
Two foot length of ½" PVC pipe ($2).
Use it like a big straw. Put your thumb over one end, dip the other end ~18" below the surface, momentarily release your thumb and the pipe fills with water, put your thumb back on, and extract the water filled pipe.
Empty the pipe's water into a plastic condiment bottle ($1). Makes dispensing sample water very easy and precise. Arm stays dry too.
No, nor should they be able to. Test results should be uniform throughout your pool. If they are not, you are not circulating the water well enough.has anyone proved that samples at different depths are significantly different?
Would water temperature affect any of the tests? If you happen to test when the pool is very still, the top few inches would be some amount warmer than a couple feet down.No, nor should they be able to. Test results should be uniform throughout your pool. If they are not, you are not circulating the water well enough.
Chlorine, CYA, baking soda, salt,muriatic, etc. all seek "dynamic equilibrium" wherein the molecules flow from any higher concentration to a lower one. We rednecks call that "stays mixed up"
I use plastic water bottle without the lid and put my palm over the top as I'm putting it in, and stick my arm in the deep end to like arm pit level. Then I take my palm off the top, get some water from a few deep and test.
If that’s true then water 2” or 2’ deep should be the same. Next to the return or a foot away from the return shouldn’t matter either.No, nor should they be able to. Test results should be uniform throughout your pool. If they are not, you are not circulating the water well enough.
