Hi all,
I am really puzzled and would so appreciate your wise insight and suggestions, everyone! My pool water has been pretty clear since opening about 3 weeks ago, but it isn't now. The pool is consuming more chlorine and looking worse. Today the water was really cloudy! I could make out the drain in the deep end, but NOT clearly.
Here are today's readings:
CYA 40
FC 6 (started at 9)
CC 0
TA 290
Ph 7.6
CH 175
QUESTION: I did the OCLT and lost about 3ppm overnight. However, this test was done after another day of heavy swimming (8 swimmers 8 years old and younger!) So my question is this: Is it reasonable to see a 3ppm drop in chlorine level (during the daytime)l after the pool gets some big-time use like this?? I understand that a drop in chlorine level greater than 1ppm overnight indicates that some organic matter is present and the pool requires a SLAM. But could it also mean that the FC is doing it's job???
QUESTION: Based on this info, does it look like I need to increase FC to 16ppm now? How long do I need to hold it there to make sure I have killed everything bad? Thanks for the help.
CYA 40
FC 6 (started at 9)
CC 0
TA 290
Ph 7.6
CH 175
