- Jun 27, 2022
- 20
- Fiberglass
- Hayward Aqua Rite (T-9)
Hello TFP community! It's been one year since becoming a pool owner and joining TFP. I have learned so much but still have a ways to go, especially in the confidence dept. We started the year with a pump that died and the SWG also went out - they were both 10yrs old. All have been replaced and are fully functioning. I am currently struggling with the inability to get my pool crystal clear - I've seen the pictures you all have posted and know it's possible, I just can't get there. Also fighting high TA and PH drift - I worked at it all year last year and never got the TA below 120ppm (we are on well water). I use the Taylor K-2005 and got the FASDAP for testing chlorine, and the K-1766 for salt. Here are my numbers this morning:
FC -11
CC - 0
PH - 7.8
TA - 150
CH - 140
CYA - 80
Salt - 3600 (I think is too high)
Water temp - 83*
SWG is set at 40%. Haven't found the sweet spot to maintain FC at 8-9 with regular usage.
The pump runs for 12-14hrs/day
Last week the pool was almost crystal clear (that sparkly clear) but still not there. We had a pool party on Saturday with lot's of swimmers and for the past 2 days the water has looked dull - not cloudy, but definitely not clear. What am I missing? Am I wrong that my numbers look OK? I know I need to drop the PH some and will continue to try and get the TA down but it's a constant battle. I primarily use muriatic acid, cyanuric acid, pool salt and occasionally liquid chlorine. I've never used any other chemicals since owning the pool. I'd appreciate any and all suggestions to get my pool crystal clear with healthy chemical balance. Thank you!
FC -11
CC - 0
PH - 7.8
TA - 150
CH - 140
CYA - 80
Water temp - 83*
