Anybody bought from travertinemart.com? How was the quality? After seeing some photos posted here. I would really like to use travertine instead of unilock if the price is not too high. Any suggestions where to buy?
Search on “travertinemart” and you will find a bunch of positive threads about them.
OMG, I am so excited. At this price, I am willing to change PB and wait for next yr if he gives me a hard time. My “smart”husband kind of worked backwards by given our budget first then negotiated all the things we wanted in.
The only question that can be called stupid is the one not asked! If you don't know the answer or are unsure of a answer that was give then please ASK! We will tell you what we think and try to be nice while doing so!!my stupid questions.
The only question that can be called stupid is the one not asked! If you don't know the answer or are unsure of a answer that was give then please ASK! We will tell you what we think and try to be nice while doing so!!![]()
Here’s a pic from the front view. But it is not showing how steep the slope is. If you look at the sketch and the front view, my property line is the stone wall under the trees. We only have a few trees on our side of the stone wall and that will be removed. the pool will be 25ft away from the stone wall/ my neighbor's trees
It will be a little tricky working around the septic. Is that the tank cover marked with pavers? Where will your main approch to the pool be? Is there a door on the side of the house? Can you take a pic looking from the top of the hill by the septic towards the house? Unfortunately the pics will not give enough information to recommend placement of the pool. There are just too many unknowns with the septic involved. 3' is the usual max fill allowed over any septic component. The more fill placed over the field the less the field can breath.
Can you post a pic of the as-built of your septic system. If You do not have one you really need to get one from the town so you can properly locate the system before any digging. You do not want any equipment driving over your field or tank. Usually regulations even prohibited the stockpiling of material on the system.
What is that huge patio area out back? Have you considered putting the pool out there?
You will love your autocover. That is a big one. As I'm sure the line item price reflects. I too have that combo of autocover and winter safety cover. I enjoy that and it works well for me. Our autocover gets more use in Apr, May, Sep & Oct than in the summer months. But both still look in fantastic shape after 7 seasons.
Bluestone coping. I have that as well. It will be hot but it looks great and since our deck is concrete, it's a little cooler than the bluestone. Bluestone coping is fine once it's wet, so I just splash it if needed. Make sure to consider the surface texture/finish of the bluestone, natural cleft or thermal. Thermal is more formal looking and probably expensive (ours is natural cleft). Also confirm the thickness of the coping. Ours varies but is roughly 1 1/4" thick around the pool. Whereas the bluestone that covers the autocover is 2" and it looks better. I highly recommend getting stone to cover your autocover versus one of their metal lid options. Much nicer looking in my opinion.
I like your corner benches in the deep end. We have them in both corners as well.
Are those 4 lights big/full size ones. You will enjoy the color changing. It really adds to the ambiance. Placement of lights? Should be facing away from the house and main seating area if possible.
How many skimmer and returns? Placement?
Highly recommend the following:
Main Channel Drain A&A Manufacturing AVSC Channel Drain Dual Suction Vinyl - Light Gray #558371
Pouralid skimmer covers Pour-A-Lid
I havent read your full post, but they did a small retaining wall for our build out of cinder blocks, then used the same travertine pavers as the patio on the wall. The pics are in my build thread below and they did this in the step down by the spa as well as the far side by the tanning ledge.Any suggestions on retaining walls to match travertine pavers, suggestions
I have Hayward Colorlogic 4.0 lights. Full size color changing LED's. 2 are certainly needed to light my pool to my requirements for all colors. Any colors other than white are dimmer than white.Thank you. Do you use SR Smith LED TREO lights? Are they big/ bright or small? IDK why the PB gives me 4, are they small? cuz my neighbor has hayward LED ligtht only 1 big one. It lights up her entire pool.
IDK what kind of returning drains my PB uses. I could ask if he could use the dual suction, its safer for little kids? I will be getting 2 main drains, 4 returns, and 2 skimmers.
Thank you Rich, my septic leach field is the orange spray painted 6 dots. The 4 pavers is my septic pump. We need to be 10’ away from septic tank and pump. My property goes to my neighbors driveway. So the truck will come from that end.
The big area rt behind the house is our deck and patio. To put put a pool there would ruin our recently built 1400 sft patio and the deck( which is a pain to maintain as of now.
I was hoping for a pic from the neighbors looking at your house. And perhaps a few from the street.
Why is your patio a pain to maintain?
Since it is a pump system and judging by how the lawn looks on top of the system I am willing to bet there is not much cover over the system. So you might be able to put some fill on top of the field but the tank could be a little deep so that might limit how much fill can go out there and the more I see in the pics the more it looks like you would not want to raise the grade over the septic field. At first look I assumed your back patio was higher then the pool was going to be which is why I suggested perhaps raising the pool. But after looking at all the pics again and making a few assumptions It looks like the pool will already be higher then your back deck, so I do not think raising it any more makes much sense.
I do not see how the will get equipment and materials in and extra dirt out without going over your septic field or tank. I would definitely not want them putting anything on the septic field or driving anything over it if it is as shallow as I think it is. Is there enough room for them to get between the woods and the field? Is there a vent pipe in the woods?
You can also be certain they did not bring those boulders on to the site because they look so nice in your lawn. You can probably expect some extras in the excavation cost if they have to deal with that size rock. I would ask the PB if he has the proper equipment to handle a few pebbles like that. You might end up with a few more lawn ornaments....
Who marked out the septic and how did they locate it?
All main drains are VGB Act compliant these days for new construction. What I'm suggesting is a particular variety which is more attractive than the circular drains, allows debris to flow in easier (because it sits flush with the plaster surface & has larger openings) and sits flat with the surface, allowing cleaners to pass by uninhibited.
We did light walnut coping (but not bull nosed shape). We were going to also use the light walnut pavers, but there was a lot of variation in the samples they brought including some that had a lot of yellow and others with a lot of grey. We switched to the ivory travertine and are happy with it.
I assume they will do your coping and tile first. I would suggest getting a couple of travertine samples to lay out next to the finished coping and tile before you make your final decision. Good luck.
