I have a new, small pool (5k gallons) that I have been maintaining with liquid chlorine. The pool does have an automatic chlorinator inline that the installer crammed with large pucks. This initial chlorine was way too high and I removed the melting pucks and started to use liquid chlorine instead. Everything is working well. However, in about a month I will be leaving home for 9 days for the first time since the pool was finished and won't have anyone available to keep up with the liquid chlorine during that time. I will use pucks for that time away, however, should I use a couple of 1 inch pucks or a single 3 inch puck in the chlorinator for that time? Would the 1 inch option be better for not over chlorinating the pool? The pool has a UV filter, and with the liquid chlorine I've been keeping the FC around 2-3ppm daily.
Thanks for sharing your expertise.
