Hi,
I'm going to upgrade to a SWG system and would appreciate some advice on the pipework as I'm a bit stumped on the best way forward.
As I understand it I need to install the SWG cell as the last item before the return to the pool. As you may be able to see from the attached photos its a bit tight. The return from the heat pump is the upper elbow on the right hand side coming through the wall, there is a non-return flow valve in this line which then has the input from the rainbow feeder and then returns to the pool via a double elbow.
Ideally I could strip out the rainbow feeder and the non-return valve, install a new piece of pipework with the SWG in it and away I'd go. However, I can't see how I'd get the pipework in place without digging out the two elbows from the wall which I'm a bit hesitant to do.
I was told once that its best to avoid too many bends in the pipework as it reduces the flow?
Any advice would be very gratefully received.
Thanks
Ian
Thanks
Ian
