I agree. I did a "best SWG" search and they came in 5th. But it seems my only choice in the UK. .....Zodiac stuff is not my first choice.
Thanks. I can't find any of these available in the UK except by buying from Amazon and having it shipped over from the US which I have to say hasn't been the best experience so far. Also if I get a dud I'd like to be able to return it so I'm going to go for buying from one of the online UK pool stores where I know I'll be able to source parts and make a return if I need to, accepting that I might then be limited in choice. "Just OK" is fine for me![]()
When I said don't worry about TA I wasn't meaning to start it up that way. I meant you could get the piping done and start salt addition. Along the way you'd probably do a few cycles of MA addition if you're like most and do this over a weekend or two. Then before you start up you bring all the chemistry into balance. Sorry, I could have been more clear. I bet Allen was thinking the same thing. I've been running TA low for a long time but in your area the water must have a lot higher TA than mine so may take a bit to get it down.I found the article which was called " TA further reading" where it says "
Why Should TA be Lowered with a SWG?
Usually a TA on the high end is fine if the pH is stable. However TA does need to be adjusted down with an SWG. The problem is, INSIDE the cell, the CSI is very different than in bulk pool water.[3]
With high TA and aeration from the bubbles the SWG creates, you'll get faster pH rise inside the cell and so there's more potential for scaling. With current reversal, the cell tends to stay clean but you'll get more snowflakes out of the returns. Calcium hardness is only one part of the equation.
If the SWG cell pH rises much above 10 (and it can easily do that) and if there is sufficient levels of carbonate ions available (CO3--), then you will get calcium carbonate precipitation. The higher the TA and pH, the more carbonate anions are available."
Basically what you said! ( maybe you wrote it !) Anyway, as you say, I'll give the fountain method a go to get the TA down as best I can and then see how it goes. The zodiac model I'm looking at has polarity reversal
Thanks again for all the help. I really appreciate it!
Cheers
Ian
ChrisIan,
Sorry you had the fit problems but at least you got your money back. The more I think about this issue the more it doesn't make sense this should prevent you from getting a salt system though. I've had to deal with this issue building the water treatment facilities for large chemical plants in SE Asia. Invariably some equipment had metric fittings connecting to Imperial. I would call these folks and have a talk. They are based in Leeds and based on the info on their website they seem very familiar with this issue. Please take a photo of the markings on your pipe that designate the size and pressure class. They will need this information to help you. I have posted a photo from a company called FlexPVC in the US that has the adapter you need in a union. I would guess there is something similar with a slip joint. If you can't find the printed information on the pipe it should be embossed into the fittings. I'd also bet there's somebody on TFP that's run into this problem before. Let me ping a few. @ajw22 @Arizonarob
I hope this is helpful.
Chris
IMHO the zodiac system was just a poor design as it clamped onto the pipe rather than being in line and the clamping method seemed susceptible to future issues even if I got it to work in the first place.
worth the wait, I never thought about metric pvc. I remember told in the 80’s we will be on the metric system in a few yearsChris
Thanks for taking the time to look at that.
in the meantime I’ve explored just sourcing a decent system that people on TFP seem to recommend with DiscountSaltPools as they have confirmed that they will ship to the U.K.
initially I was Reluctant to go down this route as I’ve have problems in the past sourcing direct from the US with returns etc but given the lack of availability of a decent system on this side of the pond I’m going to go for it.
I’m looking at a RJ30 as it has the capacity I need ( typically my FC usage is 0.5 - 1 ppm / day ), will work on 220 voltage and comes with 1.5” fittings out of the box.
so I’m going to give that a go.
Thanks again
Ian
Thanks!Exactly! The Zodiac system is an “afterthought” set-up. Quite a few people have run into problems with that system.
Going with a good in-line system will save you time and headaches down the road. Find a good retailer here in the states that will work with shipping, and it’ll be worth waiting for the equipment.
I’m not sure if the RJ30 comes with the bypass pipe, (check into that) but if not, consider picking one up as well.![]()
Haha - well we officially went metric about 40 years ago and the U.K. pipework is still all 1.5” ?worth the wait, I never thought about metric pvc. I remember told in the 80’s we will be on the metric system in a few years![]()
Thanks for the help Chris- will update once I have a system.Here's a photo of my installation. My pipe is 2" but the kit comes with adapters for 1.5". If you use a horizontal loop like this you'll need to fabricate a saddle support where the temporary wood supports were in this photo. It's easy to make a PVC pipe saddle support out of scrap.
Chris
Thanks!
showing my lack of knowledge once more!
What is the bypass pipe for?
Thanks - I’ll definitely get one !If you need to service the cell, the pipe slides into its place. That way your pool can continue to operate while it’s out.
Thanks - I’m going to call them this week.Ian,
The bypass is what I referred to as the spool piece previously. It's in the maintenance kit. I think it's more commonly called a bypass in the pool industry. Construction industry we call it a spool piece.
Chris
