- May 3, 2020
- 66
- Plaster
- Pentair iChlor 30
Marvelous - thanks @JamesW for sharing - that explains why it's there...The problem with the SLVS is that there is always stagnant water in the lines and this can breed algae, bacteria and other nasty biological hazards.
Done2024 Annual Donation Campaign
Hi all, Thanks to the fervent support of the TFP community, we have met our $10,000 goal! We appreciate all the users in this thread hyping the campaign and sharing warm and fuzzy TFP anecdotes. Completion of this campaign reminds us that TFP is a resource that people can trust with their pool...www.troublefreepool.com
Possibly.I also agree with you on the stagnant water - could any of it seep into my pump / pool and be the cause of the Chlorine drops I'm seeing?
It might develop a biofilm and that can be difficult to remove.I wonder if I need to do something there by adding some (or a lot of?) chlorine to kind of neutralize whatever is in there?
The line should have a screen to prevent animals from getting into the line as shown in the picture above.Because I can see dirt in there and I can imagine one or the other lizard might get in there, regret that decision, die and start to decompose...
Because it is considered to be a safety system, I can’t recommend eliminating it or disabling it.Or should I consider capping it all together?
How would I go about blowing it out?Maybe verify that it is indeed a SLVS by blowing it out while the pump is on to see if the air goes into the pump.
I was thinking of going the other way around and using a pump (on low setting) to remove some the water - I should then be able to see if the current water is dirty / cloudy. And hopefully that may suck out any dirt as well.Maybe a compressor or blower if it can produce that much pressure.
Don't over pressurize because we are not 100% sure that it is a SLVS or exactly what it is.
You can probably even use a garden hose and just push water into the pipe and watch the pump basket to see if any dirty water goes into the pump basket.
Maybe wrap a rag around the garden hose or maybe some tape to make it big enough to just fit in the pipe and have someone hold it in the pipe while you watch the pump basket.
