PH too low
tim5055
10,897
Franklin, NC
I have 24 lbs of baking soda. I’ll add 12 right now. I took out the tablets and I have 5 gallons of bleach.
If that's normal 6% bleach add 2 bottles. If they are actual gallons of chlorinating liquid 10 or 12.5% only add one.
You will probably need that 12 poinds, but try to only add half right now. We like to move up in stages so we don't overshoot our target.
tim5055
10,897
Franklin, NC
Good on the clear water. The liquid chlorine should be poured slowly in front of a return with teh pump running. Wait about 15 minutes and add the baking soda. It will probably dissolve as fast as it's added, but brush it around if not.
jt4200jt
22
Sulphur Louisiana
Ok...I already added the 12. I’m gonna add the 2 gallons right now. When should I sample again?ok
Ok I did that. Should I sample tomorrow after I get off work?
tim5055
10,897
Franklin, NC
Hey y’all I sampled the 3 samples. Here are the results:
FC 4.4
PH took 18 drops to get to a 7.4
TA 50
What should I do y’all think I should do?
OK, we have saved the problem you showed up with, low pH & TA.
Now, to your bigger problem - that sky high CYA. If we assume the CYA is 100, then you need to keep the FC at 15 all the time and you are will below that now. So, you need ot add more chlorine now.
You need to get that CYA under control, and the only way to do that is replace water. I have already linked to a few articles and one of them was how to chlorinate you pool. You need to read thru that. If you are going ot continue to use liquid chlorine then you need ot get that CYA down to the 40 - 50 range. If you convert to salt and add a Salt Water Chlorine Generator then the CYA should be around 70.
More chlorine now, no more baking soda for now and you need to do some reading in pool school and decide how you want to maintain the pool moving forward.
IceShadow
2,177
Milwaukee, WI
FC at 15? Isn’t that high? When you say replace water, you mean drain the pool, and replace the water?
It is high, but with your CYA so high it would need to be that high for it to work to fight algae and keep the pool sanitized. That’s why we’re recommending you change out some water.
First we need to know how much to exchange, so we need a better idea of the CYA level. Do the test again but this time add equal parts tap water and pool water and mix those together first. Then test that water with the CYA test. Multiply the result by 2 and let us know what you get.
Also, if you can fill out your signature with the type of pool, size, equipment, etc. it will help us with future recommendations. :)
tim5055
10,897
Franklin, NC
No, actually 15 is a little low because we don't know where your CYA really is.
We are past the emergency get it fixed because the TA crashed stage and now into the learning to take care of it stage. You need to read what I posted before and start to un-learn your old bad habits and learn the new ones.
Read thru these:
jt4200jt
22
Sulphur Louisiana
Thanks! Yes I will continue to read through the info you posted. Yes I need to learn how to take care of it the right way. I did the CYA test with half tap/half pool water and I got a 55. So if I multiply that by 2 it’s 110. Do I need to do a partial drain of my pool? I have a liner, so I know I can’t drain too much.
IceShadow
2,177
Milwaukee, WI
You can't really measure 55 - if it's between 50 and 60, you call it 60. So call your CYA around 120.
I would recommend a no-drain water exchange. You could drain the pool down to about a foot in the shallow end left on the liner, but the exchange is safer. Basically you have a submersible pump pumping out water from one end of the pool (deep or shallow depending on the temp of the fill water vs the pool) and a hose filling the other side. Leave the pump off, measure how much water the pump sends out each minute and you can figure out how much water is being replaced per hour. If your CYA is around 120 then you really want to replace about 66% of it to bring it down to CYA 40 or so. Then your FC levels will be much easier to manage.
Here's info on the water exchange:
jt4200jt
22
Sulphur Louisiana
Thanks so much! I'm about to start that.
IceShadow
2,177
Milwaukee, WI
The key is to disturb the water as little as possible once you start. You don't want it to mix up - you want it to stratify and make layers, with the old water where the pump is and the new water filling in from the hose. :)
jt4200jt
22
Sulphur Louisiana
Hey y'all. So I did the water exchange, and I think it went pretty good. I just got my first round of samples after the exchange. Here are the results:
FC 1ppm
PH 8 drops to bring it up to a 7.4.
TA 90
CH 110
CYA 60ppm
Should I add 6 lbs of bacon soda, and 2 gallons of bleach?
Donldson
4,410
NW Ohio
Something isn't right here. Your pH shouldn't be that low with a TA of 90. What does the actual color of the sample look like?
Add the bleach, but hold off on more baking soda for now.
Reactions: tim5055
IceShadow
2,177
Milwaukee, WI
pH of 8, use muriatic acid to lower it down a bit. How is the water looking?
Edit: oops, thought they said pH was 8 - if it’s that low, aerate it for a while :)
