PH testing with Taylor kit. Should I do in sunlight? Indoors? In shade? Should I put it to the sky? Should I put it toward a white background? The colors all look different! What is most accurate way to view?
A consistent background is key. To get good backlighting, hold the block in front of your computer monitor/tablet/phone with a blank white screen displayed. Also, try holding the block sideways or upside down. Sometimes that helps distinguish colors better. I also use two old hotel keycards to mask off areas and narrow down my decision.What is most accurate way to view?
You should test TA and pH of your fill water. If you had high TA fill water, you'd obviously be on the muriatic acid bandwagon with me.I put it up to white background outside. 7.6 with 70
TA.
What I am concerned about and really what is interesting is that I’ve owned this pool 3 months and never manipulated TA or PH. I’ve literally just kept up the liquid chlorine levels. I’ve had rain, I’ve added water via hose when pool got a bit low, and still have proper numbers. Is that crazy?
You can take a card such that isn't used anymore and with a razor blade cut out a window for the height and width of one row so you can block all except one frame at a time. The color then will be very evident. I may try it just for the fun of it.A consistent background is key. To get good backlighting, hold the block in front of your computer monitor/tablet/phone with a blank white screen displayed. Also, try holding the block sideways or upside down. Sometimes that helps distinguish colors better. I also use two old hotel keycards to mask off areas and narrow down my decision.
Your device may not display the "true" color match as I may see with my cataract-corrected eyes . . .Not quite 7.8 but this // close.
7.785.
