I need some advice on how to get PH and TA under control so I can SLAM my swamp of a pool. At opening, PH was extremely high. The solution was purple so I have a feeling that PH was over 8.0. TA was 60. I added muriatic acid (using pool math) and I must of added too much because PH was only 6.8 and TA was only 2.0 afterwards. I made the mistake of going to a pool store for water testing and they told me to add some soda ash since it would increase PH and TA at the same time. I ignored their dosage advice, and added the amount on the pool math calculator and it increased TA to 50 but it increased PH to 8.0 which was much higher than my target of 7.2. Since I carefully measured it out and only added the amount that the pool math calculator said, I don't understand how this happened. Since I need to SLAM my swamp of a pool, I assume that I need to lower it with muriatic acid again but I'm worried about making another mistake since I'm eager to SLAM. Since TA is only 50, do I need to increase TA with some baking soda before I lower the PH with some acid, since the acid will lower the TA, or wait and increase it if the muriatic acid lowers it? If so, what TA level should I shoot for and how long would I need to wait between adding the baking soda and adding the muriatic acid since both affect PH? Since I'm apparently bad at determining how much muriatic acid I'm pouring into the pool, I'm open to any suggestions on how I can safely measure out the dose next time. If I used one of the safer "green" muriatic acids like "Jasco Green" or "Kleen Strip Green," could I pour it into a plastic measuring pitcher (wearing gloves and goggles, of course) like I do with the liquid chlorine?
