Hi all. The PH of my recently renovated (9 months ago) in ground pebble finish SWG pool consistently creeps above 8 within 24 to 36 hours after lowering to 7.5. The water looks great and the surface of the pool is clean.
Here are my numbers as of this morning:
FC - 4
PH - 8.2
TA - 60
CH - 250
CYA - ?
Salt - 3200
Should I assume the relatively quick PH rise is due to the new(ish) pebble finish, low TA or both? Other thoughts on what to do to stabilize PH based on my numbers?
Thank you.
FC - 4
PH - 8.2
TA - 60
CH - 250
CYA - ?
Salt - 3200
Thank you.
