- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
This is the 1st time this has happened to me in the 2 years I've been managing the pool. I've always done the TFP method, and it's been great! While my neighbors have pool service companies coming once (sometimes twice) a week, and they still experience algae blooms ... I've never had any troubles for two years
Today my pH was reading 8.3, TA 100, and Borates 50 ... so I dosed what Pool Math told me to (as usual) to hit 7.5 pH, which was 117oz of 31.45%. About 1.5 hours later, I retested and the pH fell to 6.8 and TA dropped to 60? I'm fine with the TA being so low, and will run the waterfall and just wait for the pH to come back up (which should only take a day or 2 given our evaporation rates right now and the high TA fill water I have), but this makes me uncomfortable to have it overshoot so much.
The only thing different today from the past 2 years is I used Klean Strip 31.45% muriatic acid instead of the KemTek 31.45% I've always used in the past. When I went to Lowes to get some KemTek last weekend, they were completely out of KemTek everything in the pool/garden section ... so I went inside and grabbed the Klean Strip. This isn't the "low fumes" version, but the blue label one which has 31.5% | 20* Baume stamped right on it.
I used the Klean Strip for the 1st time last weekend, and it hit the target exactly as Pool Math predicted ... but today, it significantly overshot the projection.
My initial thought was my pH buffer (Borates) was gone somehow, but I retested today and verified it's reading 50.
When I dosed the 117oz today, I used 60oz from the same bottle I used last weekend, and then 57oz from a 2nd bottle which I had to open today. Maybe it's possible this 2nd bottle is much stronger than 31.45% due to some error at the factory? Is there a way to test the consentration of it with my TF-100 kit?
I can't figure out what else could cause this, and I'd really like to know what happened here so I don't accidentally crash my pH in the future.
