Hi everyone, I have done extensive research on this topic but I think I need a little help putting together a plan of attack when it comes to addressing the pH balance in my pool.
Background:
I took over maintaining my own pool and recently, and also drained and refilled the water. After filling, the TA started off ~145, so I have slowly brought it down to ~90 using muriatic acid while simultaneously battling high pH. My pool has a spillover which may be contributing to the continual rise in pH, and my TA also has a tendency to rise on its own.
The issue:
My pH drifts upward rather quickly, as shown by the following:
Test results from 5/10 (~1 day after adding MA with the pump on):
pH: 7.4
TA: 90
Test results from today, 5/13:
pH: 8.0
TA: 90
My goal is to keep LSI in check and prevent scaling, but with these numbers, I'm needing to add acid every 2-3 days to avoid going well over LSI of 0.3.
What do you recommend? Should I bring the TA down lower, or am I risking even faster swinging of the pH? Should I try the borates technique?
Any assistance is appreciated.
Here are all of my current test results/pool info in case it matters:
FC: 2.4 | CC: 0.2 | pH: 8.0 | TA: 90 | CH: 360 | CYA: 25 | Salt: 0 | TDS: 600 | Water temp: 80F | Pool volume: 10,000 gal
Background:
The issue:
pH: 7.4
TA: 90
pH: 8.0
TA: 90
