- Jun 8, 2023
- 62
- Plaster
- Hayward Aqua Rite (T-15)
Hello! Having issues with FC in my IG pool. Pool looks clear - can see all the way to the bottom; no visible signs of algae or other debris. SWG not showing any errors (it is set to 80%, shows "Generating Sanitizer", and Salt Readout is 3100). My pump runs 24 hours and is programmed to run 3450 RPM 6a-6p; 1800 RPM 6p-6a.
My tested levels are as follows:
FC: 0.2
CC: 1.0
pH: 7.4
TA: 55
CH: 190
CYA: 60
SALT: 3400 (as tested yesterday; calibrated SWG yesterday evening to 3400, this morning shows 3100)
Yesterday evening I added 1 lb of "Burnout 3" (leftover from pool store) and FC reading a few hours after was ~5.0. This morning, it was closer to 3.0. I have put 2 Chlorine pucks in the skimmer (since my CYA is on the lower end of acceptable level).
My hunch is that I have a bad Salt Cell. It's Hayward Goldline TurboCell TCELL940 #4E19161 - 201435. I opened it up a couple of weeks ago to see if it needs cleaning but there was no build up).
Any suggestions on what I should do?
FC: 0.2
CC: 1.0
pH: 7.4
TA: 55
CH: 190
CYA: 60
