Pentair Whisperflo loud noise
Welcome to TFP! :wave:
To me, it sounds like a mechanical issue either with the impeller or the motor bearing(s). Are there any recent incidents of the pump being run dry for an extended period or other issues of note?
I would disconnect the motor and remove the wet end from the motor and inspect for damage to the impeller. Based on the sound alone, I would suspect it's more likely an issue with the motor itself. If you see no issues with the impeller or shaft seal, you may need a replacement motor or have the motor rebuilt by a local machine shop.
Pentair / Purex Whisperflo Parts - INYOPools.com
Yes, water level was low on one day and pump ran dry for about two hours.
I think it's an issue with the motor. Impeller and shaft seal seems to be okay.
Called a local machine shop and quoted $150 to rebuild.
I am not sure if I should rebuild the motor for $150 or buy the motor from ebay for $230.
