Pentair Warrior SE is the Dolphin S200
Kimmmg2003
16
Columbus, Ga
Anyone else who bought the warrier pentair SE have issues with the cord raving up? I know it has the swive but mine still has to be manually unraveled. This is the only thing I have issues with.
markayash
2,592
Atlanta Ga
Mine does some but seems worse when I have floats in the pool. It still seems to clean ok, I just usually start untwisting it and move toward the cleaner.
I wondered about spraying some silicone spray around the swivel
albertg
64
Marietta, GA
Mine does as well. I just make sure to check it often. It doesn’t seem to twist enough in 2 hours to be a problem if it was good when the cycle started. Also I manually run mine so I just unwind if needed before I start.
setsailsoon
3,485
Stuart/FL
Mine tangles up a few turns each day but runs fine. At the end of a week I just untwirl it and it seems to be fine. Be sure to clean the filter once per week. Even though the basket is almost empty the filter can become plugged especially with the fine pleated elements. This reduces the suction capability a LOT.
Reactions: johig and markayash
johig
Mine does a little but it’s never a problem that affects the cleaning. There are two main things I do periodically to stop it getting bad. First, when I pull the robot out I lay the cable out on my deck and make sure it is straight. Then I coil it up carefully making sure the loops are all even, working from the robot end so the free end has freedom to move as I “reel it in”. Hard to explain here but there are many helpful videos online showing how to properly coil up electrical cords if you’re not familiar. You kind of add a half twist to each loop. (I learned dealing with guitar and speaker cables in high school, but same applies to robot cables). Try to take care of it periodically before it gets bad because eventually I think you will get permanent twists in the cable. I agree it would be preferable if the swivel worked better, though.
Reactions: markayash
