I and planning to purchase a Superflo VS and want to verify what I was told by Pentair Technical support about pump controller operation.
I will appreciate comments about the following operating characteristics:
1. When set up for relay low voltage external control (not Pentair controller) a 5 minute prime cycle will run when the pump is started on a speed cycle
2. The custom programmed speed settings will be remembered indefinitely after an extended power outage
3. The pump will operate in external control mode, if wired that way, after an extended power outage.
I read the Pentair manual and did not see these issues addressed.
