- Jul 21, 2013
- 65,575
- Plaster
- Pentair Intellichlor IC-60
The HLS is just an On/Off switch and not a thermistor.
Got it.
It just really seems like the heat isnt going into the water but exiting the exhaust.
Well, the pool company came out and proved that the suction from the drain and flow to the heater is correct.
Drained the spa into the pool, tested suction at the spa drain, refilled spa. I dont know enough to call BS, seemed accurate to meHow did they do that?
So I got a technician out to my house who checked all the same things I did (thermal regulator, HLS, water flow etc.) and he believes I have a sooted exchanger.
I've been searching but dont see any posts or videos that show how to clean soot? I've seen plenty of stuff showing disassembly of the pot and cleaning out scale but nothing on soot. If there's any existing references that people are aware of I'd appreciate it. Thanks all
A sooted exchanger can cause high stack temperatures, but it will not cause a high limit issue.So I got a technician out to my house who checked all the same things I did (thermal regulator, HLS, water flow etc.) and he believes I have a sooted exchanger.
I did end up pulling the thermal regulator the heater runs fine without it, SF temp stays around 320 and the spa will heat normally.
Ok thank you for that. The old and new (generic) thermal regulators both opened fine when run under hot water but I did not test them to 120 degree's exactly. I can do that thoughHere is what the normal exhaust temperature should be:
Note: HD models can be up to 75 degrees higher. HD models use a cupro nickel exchanger and the efficiency is slightly lower resulting in less heat transfer and more waste heat.
- Below 250 degrees...very low
- 250 to 290 ..................low
- 290 to 350.................acceptable
- 350 to 480 ..................high
- Above 480...................error/shutdown.
If you had a sooted exchanger, the stack temperature would be too high.
Since your stack temp is good with the thermal regulator out, the old and new thermal regulators are probably bad.
You might have a borderline low flow issue.
You should try to confirm the actual flow in GPM.
Also, you need to be sure they are seated correctly when installing. It took me many attempts to get the regulator seated just right so it would let the heater operate continuously.Ok thank you for that. The old and new (generic) thermal regulators both opened fine when run under hot water but I did not test them to 120 degree's exactly. I can do that though
Whats the correct seating look like? I replaced it, have it pretty flat. I'm not sure how you could tell if its seated correctly since its hidden once inserted?Also, you need to be sure they are seated correctly when installing. It took me many attempts to get the regulator seated just right so it would let the heater operate continuously.
I do in the pool (not the spa) but I have no idea what proper alignment looks like.Do you have eyeball fittings in your jet heads and are they aligned?
