How do I adjust the max heat? I have the lid off, I see the yellow reset button, but I have no idea which part of this motherboard is the max heat part.. Help!
Keep in mind that if you have the unit connected to automation using the two wire Fireman’s Switch terminals, I believe you will need to temporarily remove those two wires and install the jumper back in place. That will allow the system to wake up when you press the yellow button.
