Hello.
First start after the winter and the heater does not work anymore after ca. 15 Minutes.
At first everything was ok. I could change the temperature and it started to heat.
Suddenly only the “SPA on” light is on. I also cannot change in that mode the temperature. When I push the “Pool on” button nothing happens. I was told that I must use that mode. Only the “off” button works. No service light is on.
Any idea how I can fix that? Thanks
Update:
After one hour shut off, I can again adjust the temp. But still not possible to activate “pool on”.
It does not heat, as it shows always 126 or 91. Any ideas please?
Update:
