I have a Pentair Master Temp 125 gas heater for my spa. It's been working good for a year, but recently it will not fire up.
I hear a "buzz" sound 3 times then the "service heater" light comes on. I followed the troubleshooting guide, which determined the gas valve needs to be replaced.
This is a pain because the valve is $300, plus I'll need a plumber to install it because of all the fixed pipe.
I found that a way to make it temporarily work again:
It's only a year old, so it seems premature for the valve to be worn out.
Any help is appreciated.
- shut off the gas
- take the cap off the solenoid on the valve (after removing the 2 security screws)
- manually pull up the valve plunger
- reassemble and turn gas on
