pentair laminar
robl45
967
Parkland, FL
Hello,
I have two pentair laminar, why I have Pentair with a jandy system is beyond me, but anyway, I noticed yesterday that if I pull the laminar body up slightly so that that the plastic top piece is above the ground, the laminar works perfectly, but if I drop it back flat in the ground, its spraying all weird. Does anyone know how to adjust? I have had them out before, but they only appear to just have two knobs to attach the laminar to the top piece and not much other adjustment.
Post pics of how the laminar fits in your deck and how it works or doesn't work.
So as you can see, when its raised, it works perfect, when I put it back down, its working better today than yesterday, but you can see there is water on the edge, that is where its hitting the edge.
So how is it "spraying all weird"?
In the first pic it looks like the water plume is too far forward on the cover slot.
normally when its down, like it was yesterday when we went swimming, it is hitting the side more than that and just making a mess, I can't unfortunately get a shot of it hitting the side as much today, it is hitting the side and spritzing every second or so, but I can't get it in the picture. I basically appear to need to move the nozzle more towards the center of the slot, but from past times dealing with these, they have knops on each side that attach the top, but there doesn't seem to be any adjustment to move it side to side.
