I want to replace my existing equipment with IntelliFlow, IC60, and IntelliConnect. My existing pump is 115V but the spa bubbler is 240V.
The wiring appears to go from ground to gray control box filled with pig tails and then runs to the levers which control pool lights, spa light, and air bubbler. Another appears to go to the Jandy SWG, another to the spa bubbler, and then to heater and then from heater to pump.
I assume I can reuse existing connections for new pump and IC60 power pack. I can get rid of the light and use that for IntelliConnect if it has a plug directly or do I need to wire it into the gray box pig tail mess?
Can I assume I have 240vbased on the bubbler?
