Hi Everyone,
I run my pentair intelliflo vsf at 1,200 rpm 24 hours per day. Pump is two months old. Everything was great but started noticing air coming from return jets and also air bubbles in the pump filter. From time to time the pump makes a low squeeling noise, which wasn't there initially. Only thing I have done since day 1 in terms of maintenance was clean cartridge filter and clean out pump filter basket.
I have tightened the connections on the suction side. I have ensured a tight connection at the pump filter.
Filter runs at 3 psi when at 1,200 rpms.
Not sure if any of that is relevant but thought I would give as much information as possible.
