Hello,
We are in the process of upgrading the equipment pad on our pool. We are going to have a local company come in and move the panel, install and intellicenter, SWCG and heater. When we moved in the pump on the system was a 1.5 HP whisperflo that always sounded like it was at the end of its life. I was able to pickup an older Intelliflo VS 227T from a neighbor that was getting rid of their pool. I ran a quick test on the pump and it started up, pulled water from the suction and seemed to operate just fine and sounded much much better than the old pump.
I had to swap out some of the plumbing and got it installed yesterday. I ran it for an hour or so last night and everything seemed OK. This AM when I went out to restart and get a good look at all of my joints etc the pump will turn on, prime and run just fine in all 4 speed settings but after 30 minutes or so the breaker trips in the panel. There are no errors recorded on the pump when I restart.
Any thoughts on the source. I am going to run out and hook up a clamp ammeter and see what the amp draw is. The breaker it is connected to is an older GFCI type breaker. I am wondering if the breaker is bad or just can't keep up with the newer pump? Thanks for any info.
Dennis
Dennis
