- May 31, 2011
- 246
- Plaster
- Pentair Intellichlor IC-60
Re: pentair intelliflo effeciancy New numbers and a surprise
Hi again,
Wont know too much about the plumbing as i just brought the house but do know that there must be two suction runs. One from the pool and the other from the spa. Should we count the skimmer as another suction run?
Pipe diameter is 2" SCH 40 PVC.
Will get back to you with the reading at 2600rpm and the actual distances from the pump to the pool.
I got some fresh numbers on the Watts and got a surprise when i plugged them into Watts2GPM.
I calculated the pump run time for 1 water change and calculated my electricity cost to see how much it will cost for running the pump at 1 water change per day for 30 days. Here are the numbers:
850 rpm - 10.38GPM - 37.88 Hours per day - $14.68 per month (not a possible scenario)
900 rpm - 14.12GPM - 27.86 Hours per day - $11.68 per month (not a possible scenario)
1000 rpm - 16.08GPM - 24.46 Hours per day - $11.61 per month (not a possible scenario)
1100 rpm - 16.32GPM - 24.10 Hours per day - $12.87 per month (not a possible scenario)
1200 rpm - 18.76GPM - 20.97 Hours per day - $12.94 per month
1300 rpm - 22.86GPM - 17.21 Hours per day - $12.53 per month
1400 rpm - 29.22GPM - 13.46 Hours per day - $11.82 per month
1500 rpm - 34.66GPM - 11.34 Hours per day - $11.89 per month
1600 rpm - 38.16GPM - 10.31 Hours per day - $12.64 per month
1700 rpm - 39.90GPM - 9.86 Hours per day - $13.88 per month
3450 rpm - 83.56GPM - 4.71 Hours per day - $46.50 per month
I am surprised to find that i will be spending least amount in electricity at 1400-1500 rpm range!
Do you think i am on the right track? Is this accurate?
Thanks!
Hi again,
Thanks!
