Hi all,
So as the title suggests my IC40 intermittently shows no flow when the pump is running. I installed a new flow switch but the problem remained. I have done the following to diagnose the problem:
Checked the power to IC40 from Power Center (red and black wires), reads 28 volts.
When the IC40 does not detect flow and the pump is operating the voltage across the flow switch (red and black wires also) reads 0 - 200mV so the switch is closed and the IC40 should detect flow however it does not. If I turn off the pump the voltage across the flow switch reads about 2.5 volts. I don't know what the correct voltage reading should be though. I still need to check the voltage across the switch after turning off the pump when the IC40 shows good flow to see if I still get 2.5 volts or a higher reading. Does anyone know what the voltage reading should be when there is no flow? Also, has anyone attempted to remove the top (control panel) to gain access to the electronics in the IC40?
Thanks in advance.
Thanks in advance.
