My IC40 SWG recently stopped producing chlorine. Even though the salt is within the proper range (~3200) and the flow is sufficient, the low/high salt lights are flashing, and the flow light is red. Every once in a while, without my changing anything, the lights all turn green and the unit starts making chlorine as it's supposed to. But then it goes back to the state I initially described.
My local pool shop thinks I need to replace the flow switch. I'd rather not incur that expense unless I'm sure that's the problem.
I'd welcome any wisdom you may have.
Thanks
Thanks
