If it were me, I would try deleting the app from your mobile device and then re-install it. That is a fairly painless procedure and in many instances, something like that seems to work.
We installed a mesh router this week, but we were having this issue before that. Also, the OCP says internet connection is good, and remote is working perfectly. DCHP is activated and it changed the IP address on the OCP, but not sure where the IP address is coming from.Well darn.
Has any configurations on your router been changed?
Allen.Pool automation panels seem to be glitchy with modern mesh routers. Try setting up a 2.4 ghz guest network for the IntelliCenter to connect to.
Some folks needed to plug their old router in bridge mode and a different SSID to make it work.
The 2.4 ghz and 5 ghz networks on the same SSID seem to confuse the panel?
Which mesh router do you have?
Ron,Allen.
There is no issue with her panel connecting. Where she is having the issue, is connecting "locally" between her app and her OCP. The app will not connect to the OCP locally. No problem connecting remotely (via the internet/servers).
r.
Peggy,Ron,
Blowing away the app didn't work....However, we changed the network on the OCP and it works. Go figure. It worked fine on the old network for months. Oh well, don't fight city hall. Maybe it just didn't like that network anymore. Thanks for your help.
Allen,
Got it working locally. BTW, the mesh router is Eero 6.
@rynosharkI've been installing my IntelliCenter i5PS to replace my previous Intermatic control system. One thing that I've stumbled on figuring out (which will probably be obvious in hindsight) is how to connect my primary heat pump heater (AquaCal SQ-155). I have my secondary propane heater hooked up to the IntelliCenter from the fireman's switch in the heater to the GAS HEATER (J2) connection. However, I can't figure out where to add another low-voltage switch connected to the AquaCal. Thanks for any suggestions.
I have the same issue, still don't have a fix. Tech support wasn't any help.Has anyone been able to get the Sunset offset function to work? I cant find the offset function in the touch screen, android app, or the web client. All of the manuals show how you select sunset, then select an offset. It simply does not exist on my hardware. Am I doing something wrong?
What did they say?I have the same issue, still don't have a fix. Tech support wasn't any help.
Lame AF. It would be so useful. I just want to turn my pool light on for 5m 30m after dusk. Cant do that without that offset!That feature (when it worked and only from the OCP), has been wonky ever since it was included in a firmware update.
r.
Can you update to 1.047 over the internet from the panel or must it be done via the USB download method?Hi All..
FYI.... I was able to garner a tidbit of information from Pentair management just this morning, regarding future IntelliCenter firmware update(s). He asked that I pass this along to any IntelliCenter users that I might know .
There will be a firmware update coming out soon that will significantly improve the remote access experience with the mobile apps and web interface. The release will be 1.05x (final version number TBD) and it is scheduled for release in September with beta testing coming some time before that. This new release will require users to have release v1.047 already installed on their IntelliCenter or this new release will not work. So anyone that has not updated to release v1.047, should do so as soon as possible.
Pentair has updated their downloads web portal with more detailed instructions on how to update IntelliCenter firmware.
Here is the link for you..
IntelliCenter® Control System Firmware Download
Stay up to date with the newest software. Download the latest versions of our software's here.www.pentair.com
Take care...
r.
