so that timer doesnt seem to be wired to anything - hitting lever on to off doesnt turn off the pump for filter, doesnt turn off the SWCG, set nup the on off toggles and did nothing also - i dont think they wired this properly since the SWCG is on 24/7 even when pump is off - electrician coming back friday.You have the parts you need, looking at your picture in post #16 at the bottom of your electrical box in the bags. Those brackets need to be installed on the yellow dial of your Intermatic timer to switch the power on and off assuming it is wired to your SWCG.
