yes it was running. shuts down in 10 mins I run 10am -10pmThe system is running, right?
could that be it.... i dont know what that means lol.... but i can pass that on to my pool guy, or is it something i can fix?If it says Com Link Error, the IC is not communicating with the ET. There is a RS485 issue.
When I hold down more button the lights cycle and no percentage lights come on, but it’s a new cell and has no hours. When press button again the 80 and 100 lights come on which indicates the temp is around 85-90 correct?See what the cell is reading for water temperature.
See procedure in link below.
Pentair Intellichlor ICXX SWG - Further Reading
www.troublefreepool.com
Check the communication wire to the Easytouch.
85 to 95 degrees.When press button again the 80 and 100 lights come on which indicates the temp is around 85-90 correct?
IC60 Very Low Salt - K1766 Disagrees, Lack of Timely Help from Pentair
I feel like my IC60 has always read very low, but never enough to bother me and more in the higher spectrum of the +/- 500 or so ppm. However, over winter, there was a week or so when it just wouldn't report salt PPM at all, it'd just show hyphens. I opened a warranty case with Pentair, a...www.troublefreepool.com
Yes that is the actual water temp. I keep it set at 87 on the UltraTemp and that is what it reads on both heat pump and easy touch. I will confirm with a thermometer when I get back home to be sure, but it is 90+ outside here, so I doubt temp is low and it feels normal when swimming so I would say its correct85 to 95 degrees.
Is that the actual water temperature?
My flow is really high (almost to point i think pump is too big), so I do not think that is the issue. Pressure usually runs 25-28 with laminars off and 22 with them on, but everything was same last year with no issues. Since I have a cover, generally the unit is cooling and not heating this time of year so water should be cool.Was the heat pump running when you were trying to get the cell to work?
If the flow is really low and the heat pump is on, the water might be getting too hot.
Make sure that the flow is really good and the heat pump is off and try to get the cell to work.
Redo the communication cable so that the Easytouch can tell you what the salinity reading is.
Here are the additional pictures you asked forWhat is the date on each cell?
Can you show several more pictures of everything from different angles?
Can you show the wiring inside the Easytouch?
I will move wire off intelliph controller and back to easytouch and check diagnostic again to see if anything has changed.
the thing that has everyone here really stumped is it works fine in a bucket...as is, everything hooked up as normal. Its just when its put back in line. We put my old cell in the line unhooked from control so pump could run, but had the brand new cell plugged in in the bucket to test. Worked fine as it should, both new and old cell did. Put back in line...low salt. It makes no sense.Was the heat pump running when you were trying to get the cell to work?
I know it sounds hard to believe... so i ran home and repeated the bucket test.Was the heat pump running when you were trying to get the cell to work?
i zoomed in more.. if you need better I can take another after bitCan you post the picture in good resolution?
Is there a communication wire from the SWG power card to the EasyTouch?
I am trying to find out what the salinity reading is.the comm error is a secondary concern, if it is not the cause... just trying to get it producing chlorine like it always has.
salinity is around 3500 using both a lamotte digital probe and and taylor salinty test kit. they are within 100-200 of each otherI am trying to find out what the salinity reading is.
It says low, but is it 0 or 2,300 ppm or what?
here you go.You have something connected to all 3 com ports.
What goes to what?
Can you post pictures in better resolution?
Blurry pictures are difficult to see.
Can you show the J20 com port in the EasyTouch?
