Hi everyone,
I just finished installing a new flow switch on my Pentair Intellichlor IC40 because the flow light was off and I noticed the flow switch was cracked and my pool was starting to turn green. After installing the new flow switch, the Flow light is now red and the high salt and low salt lights are flickering back and forth. I’m yet to test the levels because I recently had a lot of chlorine, acid and other chemicals added by a pool guy to remove the green that was starting to form.
Any guidance would be appreciated.
Thank you
Thank you
