Pentair IC15/Salt Start Up Questions
Marco Josip
72
Philadelphia PA
Pentair Intellichlor IC-15
Getting ready for the 30 day mark after our plaster install last month. I will be adding salt the first week of May to our new pool I just built
Couple questions below regarding the first step of adding salt and maintenance to Pentair IC-15….
-The IC-15 should be set on a timer to correspond with the pump timer. Essentially, the IC-15 should only be powered on and “running” when the pump is running? Correct? I have a separate timer for the IC-15 that is on the same schedule as the built in pump timer
-How frequently should I be dissembling this thing and cleaning it out for maintenance? Is that a fairly easy task?
-Is there any specific math or calculation to know how much exact salt I should be adding to my 3,000 gallon pool? Are you essentially adding more every season/multiple times a season? Or is a once and done per year
-Will the PH level become sporadic again after adding salt? My plaster is 3 weeks cured right now and it seems that the PH level is just starting to become level and even day to day with minimal acid need
Yes
I look at my cell at closing once a year unless it shows errors.
Read SWG How It Works - Further Reading
Two 40lb bags of salt should give you around 3000 ppm. Add 2/3 and check your salt level if your pool volume is wrong.
You need to add salt when you lose salt from draining for the winterization of filter cleaning.
PoolMath - Effects of Adding
No, salt does not affect pH.
Reactions: Marco Josip
Is this normal to have this much cloudiness? The water was crystal clear a few days ago.
We are on Day 19 since plaster. I plan to add salt to the pool for the first time on Wednesday May 7th
Is the cloudiness solely because we have no chlorine in the pool? Should I be adding some chemicals to offset the lack of chlorine/salt?
We have only swam once and I’ve taken a few late night dips after my sauna sessions
First and second pics are today. Third and Fourth were last week
Why do you have no chlorine in the pool?
A pool should always have chlorine in it
Once your FC is 0 there is a good chance you have some algae.
Get 5 ppm of chlorine in the pool ASAP.
I should have just kept the pool cleaning company honestly. I have no idea what I’m doing trying to do this on my own.
The guy at the Leslie’s store said verbatim “don’t worry about chlorine until you add your salt in a week”
Clearly he’s wrong….
What do you recommend I add tomorrow liquid chlorine or something granular?
I’m leaning towards the below because Amazon will have it to my house by 8AM and it seems pretty straight forward. Add a 1LB to get it to 3-4PPM
Greatly appreciate your help AJW
Use liquid chlorine.
Do not use any products that have Blue in the name. Blue is a code word for copper which will accumulate in your pool and stain it. Watch out for Clorox products that say Blue on them.
Thanks AJW. It looks like all the Leslie’s are conveniently out of liquid chlorine in my area
I’ll try one of the smaller pool supply shops tomorrow morning
I guess for the mean time just keep my pump running 24/7 until I get some liquid chlorine in tomorrow afternoon
Maybe this is a very stupid question but….
Does bleach off the shelf at the grocery store suffice?
If you buy household bleach, you want pure liquid chlorine with no additives. Additives such as fragrances, thickeners (splashless), or surfactants (outdoor bleach) may cause foaming. Bleach with fabric protectors (Cloromax Technology) may also cause foaming.
Most Clorox bleach today says it has Cloromax Technology. They are polymers that create foaming and are not suitable for pools. Clorox Germicidal Bleach did not have additives but the December 2019 label on their website now shows Cloromax Technology. So look carefully at the label and ingredients on any Clorox bleach products you intend to use in your pool.
CloroMax is the addition of a alkaline and oxidizer stable poly ionic surfactant chemical. It’s added to the bleach to leave behind a residue in clothing and on surfaces that resists staining and microbial contamination. It supposedly reduces the need for higher concentrations of bleach to do the same cleaning job.
Most retail bleach is manufactured by a few chemical suppliers. KIK corp is probably the biggest. They all use the "CloroMax" technology that Clorox patented and then licensed out. So even the store brands like Target or Walmart will say their bleach is regular unscented, etc and somewhere on the bottle will be the phrase "Fabric Protection Technology" (or some combination of words like that). Read bleach labels carefully and look for code words that may imply it has additives other then chlorine.
Did you look at Walmart yet? They or a real mom and pop pool store should have it. Leslies must have a distribution problem if they do not have it.
It looks like they do in 4 packs
The SKU I originally looked up on the app for 2 pack is showing out of stock
Do you guys recommend liquid conditioner for the CYA levels? Looks like Leslie’s pool app based off my results saying I need 54OZ of Liquid Conditioner OR 1Lb powdered conditioner
Regardless of the pack size that Walmart shows you will often find them in two packs or just singles when you actually go into the store. Watch the date codes and get the newest bottles you can find. The date code will be something like 3725 meaning the 37th day of 2025 for example. Get granulated CYA and put it in an old sock that you then hang in front of a pump return to the pool so it can slowly dissolve. You can periodically squeeze the sock to help it disperse.
Thanks
Yea I really don’t want to buy a 4 pack of chlorine considering it will be a salt pool I don’t think I’ll ever use it again after we add salt
Your expectations for what the SWG will do for you are too high.
Use liquid chlorine to set a FC level and use the SWG to maintain th3 FC level.
It is always good to have some liquid chlorine on hand should you find your FC low.
Hey guys, my chlorine level keeps dropping down each day even thought I’m adding 10-12 oz a day.
Is that normal? Solely because the sun?
Keep in mind pool is newly plastered, we’re on day 20 probably adding salt middle of next week
We will not give water chemistry advice based on Pool store testing.
Get your own test kit - Taylor K-2006C or TFT Test Kits - and post your results.
