Updating here for others with this problem. My Globrite lasted 5 years before failing. Unlike some where the seal at the front fails and water gets into the electronics, mine the case actually cracked and water penetrated from the molded plastic that failed. Hopefully these pictures help explain.
I just replaced mine with a new one. To replace it is was very easy, I hooked a pull string to the old cable and pulled the old unit out, tied the pull string onto the new light cable in my spa and pulled it back. Pretty basic, I can easily drain my spa which makes it even easier. Also, since these are 12V, very low risk of electrocution unlike 120V lighting. Still be safe and power off everything before working on electrical and if you aren't comfortable call in a professional.
I have a total of 4 Globrites, 3 in my pool, 1 in my spa. I am hoping that the other 3 don't have the same defect as the spa since they are very expensive. I did apply silicon around the front area around the back of the lens where it meets the casing to avoid potential water penetration in the future. This is an optional step others on this forum have done which I recommend as well.
In the images you can see the silicon I used to seal it. I hung the unit to let it dry in the sun. You can see the water damage inside the light, it likely was a slow leak that slowly caused it to fail. The light would still turn on and switch between blue while dimming on and off, but no other colors would work. I may open it up to see what is inside out of curiosity. Here is hoping the new one lasts at least 5 years or longer.
