Like so many others, I have encountered failure on two out of my three Pentair GloBrite in ground pool lights. Interestingly, the two failed within days of each other, while the third is still operating, for now.
I'm looking into Florida Sunseeker replacement options, as OEM Pentair lights are almost double the cost, hard to find and subject to early failure. I'm attempting to remove one of the GloBrites and it will not easily come out of the niche. I've rotated the face of the unit about 1/8 turn according to the manual, it frees, and then I can wiggle it out of the niche about 1 inch. From there I cannot get the unit to pull out, it's providing a lot of resistance. On the other end near the transformer box I'm looking for signs of wire movement, to see if my moving the bulb corresponds, and there is no movement of the wires.
My questions are:
1) do I need to apply a lot of force, or leverage to pull the device out of the niche? It seems excessive. I would've thought that once rotated, the light should easily come out, however, it's anything but.
2) will this model work as a replacement?
POOL TONE NICHELESS 1 1/2 INCH SWIMMING POOL OR SPA LIGHT 15 - 100 FEET
Thanks!
My questions are:
PoolTone⢠Nicheless 1 1/2 inch (large face) Swimming Pool or Spa Light 15 - 150 Feet
Replacement for Pentair Globrite Zodiac Jandy pro series hayward colorlogic 360 180 JLU4C9W50 JLU4C9W100 JLU4C9W150 JLU4C20W50 JLU4C20W100 JLU4C20W150 JLU4C30W50 JLU4C30W100 JLU4C30W150 JLUW9W50 JLUW9W100 JLUW9W150 JLUW20W50 JLUW20W100 JLUW30W50 JLUW30W100 JLUW30W150 JLU4C6W50 JLU4C6W100...
www.florida-sunseeker.com
Thanks!
