I have a Pentair Easytouch (8) control system with the Easytouch Wireless Remote that is not connecting to the control panel and reading 'No Comm'.
It started to loose connection with the panel last weekend. I was able to reconnect the remote two times by doing the following:
- Power down the control panel at the main breaker and then power back up
- On the control panel, go into 'menu', then 'settings', then 'wireless address'; the main panel indicates it is sending the address
- On the remote, go into 'menu', then 'settings', then 'wireless address'; the remote then searches for the signal
This morning, this process did not work; the remote continued 'searching' and didn't find the address.
I am looking for recommendations to diagnose the problem. My wireless remote batteries are fresh, my antenna is located under a covered porch and therefore, out of the elements.
Approx. 2 months ago, I purchased a Warrior Pool cleaner therefore, I deleted the program associated with my previous pool cleaner booster pump. In addition, I had to replace the GFCI outlet on the right side of the panel which protects my pool lighting circuit (previous GFCI failed). The pool remote worked find after those modifications.
Thanks!
Thanks!
Thanks!
Thanks!
