Pentair Easytouch Control System Stays in "Time-Out" Mode
reddingnative
19
California
I have a Pentair Easytouch Control System installed new in 2019. It's been operating as intended until last year. "Auto" and "Service" Modes operate fine. When "Time-Out" Mode is selected, the Control System is supposed to return "Auto" Mode after 3 hours. In this case, the Control System stays in "Time-Out" Mode and the pool equipment will run forever unless you manually set the controller back to "Auto" Mode.
Red,
I have three pools and three EasyTouch systems. In the past 10 years I have never used time-out.. I use Auto and Service modes.
I don't know the answer to your question, but... what are you using time out for??
Jim R.
Hi Jim-
I have my pool serviced weekly and the tech will normally set it to time out after adding chemicals or checking equipment. Today I had a new tech and he wasn't aware of the time out issue, so when I returned home it had been running. So we end up texting back and forth. Thanks
Hi Jim-
Did you ever figure this out? We purchased our home in August and the timeout mode has never flipped off after 3 hours: we’ve been resetting it manually . It sure would be convenient, so wondering if there’s a way to reprogram it.
