- Jul 21, 2013
- 65,717
- Plaster
- Pentair Intellichlor IC-60
Correct.So what you are saying is that I need to test the fireman switch relay.
Right now I have the two yellow wires at the bottom of this switch connected with a wire nut and the wires from the Jandy are not connected (which allowed me run the heater from its control).
Good. That proves your heater works fine.
What do I need to do to test the fireman switch?
You mean the heater relay on the board?
As discussed above use the continuity test on your multimeter and see if the relay closes when you request heat on the Aqualink. See post #15.
