M,
Ok, that makes a lot more sense, thanks for the update.
If you have a voltmeter, you need to test the output voltage which should be 24 Volt AC. In your pic, the high voltage come in the top pins and the output is at the bottom two pins.
You should measure about 24 volts AC between the two pins. It may be 30 volts are so. It should not measure 120 Volts AC and if it does, it should have blown a fuse, or destroyed whatever circuit it was connected to.
Keep in mind this is AC voltage and not DC. Do not measure to ground. Just measure between the two bottom pins.
It looks like the transformer in the pic requires a 240-volt AC input voltage. Test between the pin marked Com and the one marked 240 and make sure you have about 240 Volts AC,
Please let us know what you find,
