Agreed and I should clarify to test in an inconspicuous area.I don't know if I would risk applying muriatic acid directly to the dry PebbleTec surface. I think it will bleach out the dark finish.
Highly unlikely unless the CYA is way over 100 ppm.My PH is at 7.0 and TA at 270.
What specific test kit are you using?My PH is at 7.0 and TA at 270
PoolMath is just a calculator, nothing more. If given a target, PoolMath will calculate how to achieve it. It's a useful tool but needs to be used properly. Don't blindly follow its output.Pool math app says
Neither. pH will rise quickly with low pH and high TA.So, should I add borax or just aerate?
