- Feb 3, 2021
- 13
- Vinyl
- Jandy Truclear / Ei
We have an overflow drain installed and it is causing run-off issues in our yard and our neighbor's yard. We ended up putting in a sump pump to pull the water away from the yard and now the sump pump has stopped working. We are in the process of getting it replaced, but I wanted to see if anyone here has a suggestion how to fix this issue any other way. Our yard is sloped so the spot we currently have for the overflow is our option. I have added pictures for reference.
Thanks in advance for any advice or suggestions.
