- Jun 13, 2016
- 115
- Vinyl
- Pentair Intellichlor IC-40
Like so many, I need something to do and thought I'd try opening the pool myself this year. I'm not so much in a rush to get in the pool, more to just get the water cleaned up (it's not bad at all mainly leaves and worms) and ready for action when it gets warm enough.
I just want to be sure I don't mess it up (if that's possible). I've removed the tarp cover that I had, added water to the center of the skimmers, and I closed the automatic cover. Step 1 done! Then I removed the Gizzmos from each skimmer. Stopped at that point. Here's my best guess on next steps:
- Replace SWCG (has a winter blank replacement tube).
- Replace the two pump plugs and the cartridge filter plug. (touch up o-rings with silicone)
- Remove the covers/plugs from the four returns and replace with the regular return jet covers/holes.
- Open four valves that go to the returns.
- Open two of the three valves that come from the two skimmers and the drains. There are three valves, but one was left open apparently last fall by the person who closed the pool.
- Prime the pump and fire it up. (what is the best way to do this to get the flow going?)
- After the pool has circulated for a while, test the water and start balancing.
- TA (this is a tough one - always have had high TA)
- pH
- CYA
- Ca (seems to always be fine)
- Salt
- Start the SWCG once balanced and the water temp is high enough.
